Status: Open
Status: Answered
Status: Closed
Status: Duplicate
Appworks Setup Issues
Posted Feb 03 by Ramesh Chalamalla.
I'm facing issues while setting up the Appworks Gateway installation. I have installed Appworks Gateway 16.3.1, JDK 1.8.144 and Tomcat 8.0.47. When i launch the browser using http://localhost:8080/gateway tomcat logs are throwing the exceptions below.
from gateway-otag log#
> ERROR services.impl.PersistenceServiceImpl - We were unable to create
> the database connection. No opentext.properties file defined.
> com.opentext.otag.exception.DBException: No opentext.properties file
> defined. at
> com.opentext.otag.services.impl.PersistenceServiceImpl.getEncryptedPropertiesFromFile(PersistenceServiceImpl.java:495)
> ~[classes/:?]at
> com.opentext.otag.services.impl.PersistenceServiceImpl.getOpentextProperties(PersistenceServiceImpl.java:466)
> ~[classes/:?] at
> com.opentext.otag.services.impl.PersistenceServiceImpl.getEMF(PersistenceServiceImpl.java:434)
> ~[classes/:?]
At the same time i can see from gateway log file the below error#
> 2018-02-03 16:19:42,6682018-02-03T16:19:42,668 [Thread-6] INFO
> service.impl.StatusBeanImpl - ==Attempting to jump starting Gateway
> services, this node may already be configured 2018-02-03
> 16:19:42,6682018-02-03T16:19:42,668 [Thread-6] ERROR
> service.impl.StatusBeanImpl - Jump start failed, the Gateway may not
> be setup yet com.opentext.otag.exception.OTAGException: We were unable
> to create the database connection. No opentext.properties file
> defined.No opentext.properties file defined.
Appreciate if some one helps out
Hi
Those logs entries are expected as the gateway database connection has not yet been setup , as you haven't got that far in the setup process.On startup the gateway looks for the opentext.properties file which it needs to decrypt the contents of to connect to its database if it can't find the opentext.properties file it assumes its a new install and will start the setup process.
Dont use localhost use the IP or FQDN of the host upon which you are running the Gateway Tomcat on when trying to access the gateway in a browser.
If you are unsure of the hostname the gateway has been given take a look in the Tomcat. Catalina log and early on in the startup process you should see the hostname Tomcat has advised the gateway of so use that
Hope that helps
Simon
Thanks Simon for your quick response, it worked with IP address.
HI
No problem at all
I will close the question as answered if thats ok with you
S
Yes sure
Statistics
Related categories
Your answer
