Status: Open
Status: Answered
Status: Closed
Status: Duplicate
Support for AppWorks Gateway to connect to SQL Server with an encrypted connection
Posted Mar 28 by Matthew Barben.
Hi There,
I was wondering if there was a support statement from OpenText covering connecting an AppWorks Server to a SQL Server where the connections to the SQL Server are encrypted.
We are in early planing phases and I was curious to see how other customers have encrypted the AppWorks database when it is deployed into a DMZ.
Regards,
Matthew Barben
1 Answer
Hi Matthew,
It is not a supported scenario at present with either AppWorks Gateway 1.x or the soon to be released 16 version but it can be considered for a future version of AppWorks 16
Regards
Simon
Statistics
Related categories
Related tags
Your answer
